Le CP320 d'Aerodyne
Re: Le CP320 d'Aerodyne
http://cp320.blogspot.com/2022/01/fabri ... ntage.html
http://cp320.blogspot.com/2022/01/gabar ... niers.html
http://cp320.blogspot.com/2022/01/fabri ... rface.html
http://cp320.blogspot.com/2022/02/align ... laile.html
http://cp320.blogspot.com/2022/02/evolu ... -bord.html
http://cp320.blogspot.com/2022/02/les-t ... anche.html
http://cp320.blogspot.com/2022/02/align ... re-et.html
http://cp320.blogspot.com/2022/02/le-su ... es-de.html
http://cp320.blogspot.com/2022/02/fabri ... gants.html
http://cp320.blogspot.com/2022/02/trait ... rface.html
http://cp320.blogspot.com/2022/02/suppo ... frein.html
http://cp320.blogspot.com/2022/02/model ... inage.html
http://cp320.blogspot.com/2022/02/conce ... llage.html
http://cp320.blogspot.com/2022/02/fabri ... rcage.html
http://cp320.blogspot.com/2022/02/peint ... andes.html
http://cp320.blogspot.com/2022/03/vadim ... raude.html
http://cp320.blogspot.com/2022/03/derni ... avant.html
http://cp320.blogspot.com/2022/03/le-sy ... rmine.html
http://cp320.blogspot.com/2022/03/palon ... eints.html
http://cp320.blogspot.com/2022/03/model ... raude.html
http://cp320.blogspot.com/2022/03/calag ... laile.html
http://cp320.blogspot.com/2022/03/model ... et-de.html
http://cp320.blogspot.com/2022/03/une-g ... ne-le.html
http://cp320.blogspot.com/2022/03/model ... suite.html
http://cp320.blogspot.com/2022/03/petit ... resse.html
http://cp320.blogspot.com/2022/04/assem ... laile.html
http://cp320.blogspot.com/2022/04/renvo ... ndeur.html
http://cp320.blogspot.com/2022/04/palon ... inage.html
http://cp320.blogspot.com/2022/04/colla ... fuite.html
http://cp320.blogspot.com/2022/04/prepa ... vures.html
http://cp320.blogspot.com/2022/04/cest- ... -aile.html
http://cp320.blogspot.com/2022/04/trava ... raude.html
http://cp320.blogspot.com/2022/04/les-c ... leron.html
http://cp320.blogspot.com/2022/05/les-volets.html
http://cp320.blogspot.com/2022/06/un-mo ... raude.html
http://cp320.blogspot.com/2022/06/netto ... roues.html
http://cp320.blogspot.com/2022/06/colla ... e-des.html
http://cp320.blogspot.com/2022/06/lycoming-o320e3d.html
http://cp320.blogspot.com/2022/06/on-co ... ettes.html
http://cp320.blogspot.com/2022/06/des-r ... elage.html
http://cp320.blogspot.com/2022/06/reali ... ts-du.html
http://cp320.blogspot.com/2022/06/reali ... te-de.html
http://cp320.blogspot.com/2022/06/trait ... es-de.html
http://cp320.blogspot.com/2022/06/assem ... erons.html
http://cp320.blogspot.com/2022/06/rempl ... teurs.html
http://cp320.blogspot.com/2022/08/insta ... dange.html
http://cp320.blogspot.com/2022/08/fabri ... e-usb.html
http://cp320.blogspot.com/2022/08/peint ... rs-du.html
http://cp320.blogspot.com/2022/08/fabri ... -pour.html
http://cp320.blogspot.com/2022/08/passe-paroi.html
Je les ai fait en inox, ils sont donc un peu plus longs que les originaux pour avoir la même masse. C’est mon collègue Nicolas qui les a usinés en commande numérique.
Que comptez vous mettre comme verrière ?
Vous allez la réaliser vous même ou utiliser une déjà faite ou acheté à prix d'or ?
Si vous la réalisez vous même et comme il m'en faut une je serai partant pour 1 exemplaire, je peux fournir un arceau complet de CP1315 Scintex au cas où comme modèle si celui de Michel ne convient pas.
Todd Canopy aux USA fournissait des verrières sans arceau central du plus bel effet une fois installée. --> viewtopic.php?t=1855
bonjour laurent. je pense tenter d'en faire une pour voir :-)
Bonjour Matthieu
Le moulage de verrière m'intéresse énormément; j'ai réalisé un moule de pare-brise pour super émeraude Scintex.
Au delà du fait que les verrières de cP320 et CP1310/1315 sont assez différentes.. Ce qui m'intéresse c'est le processus de moulage et la conception de l'outillage: four, moule...
Luc
Luc
Bonjour Luc
Je suis à la recherche d'une verrière complète pour CP1315 Scintex, je suis donc fortement intéressé si jamais tu envisageais de pouvoir tirer plusieurs exemplaires pour amortir tes frais ???
Tiens moi au courant si c'est jouable ?
Bonjour les copains
Desolé avec ma fin d’année chargée je n’avais pas vu vos messages.
Je compte effectivement tenter de mouler moi même ma verrière pour deux raisons :
- le prix !
- la possibilité de pouvoir fabriquer une verrière exactement à la forme que je souhaite, c’est à dire plus filante que la verriere d’origine dont je trouve le rétreint trop important.
Je compte fabriquer le moule des demi panneaux de verrière avec trois couples en aggloméré montés en tenons mortaise sur un panneau longitudinal. Puis cloutage de petites lisses de bois sur ce moule. Ponçage, enduit, ponçage etc.
Ensuite la feuille de plexi montée dans un cadre en bois sera passée à l’étuve puis plaquée sur le moule en mettant ce dernier en dépression.
- le prix !
Par curiosité, la verrière du CAP 10 ne s'adapte pas ?
Si je pense mais je n’en ai pas :-(
L'aile coffrée !
