Where are you guys buying canopies.
Where are you buying the bubble canopies for the Beryl like the one on Daniels Beryl? Does someone in France make them, you making your own? Also cowlings for the Beryl.
Thanks,
Roger
Thanks,
Roger
Re: Where are you guys buying canopies.
Hi Rogerprographics2002 a écrit :Where are you buying the bubble canopies for the Beryl like the one on Daniels Beryl? Does someone in France make them, you making your own? Also cowlings for the Beryl.
Thanks,
Roger
You can contact the member "Poulet", it's Daniel himself
He known the answer
I tried last weekend to vacuum form a canopy. The box I built wasn't strong enough and I will build another one that is reinforced with metal.
Once I heated the box and acrylic sheet up to 325 degrees I turned the heaters off and the vacuum on. The canopy started to pull a few inches but the vacuum was pulling the sides of the box inward so hard the box collapsed and I lost vacuum pressure. I will try again after I build a new box in a week or two.
I will keep you guys posted as I make any progress.
PS: I got to try Hang glidding this past week while on vacation at Kitty Hawk NC.
Roger
Roger
I stretch formed mine over a male mold, the windshield has a flat front like the plans, which I thought was cool as heck. The Pazmany book "Light Airplane Construction" was my main guide on doing the canopy that way. My first choice was to work with a canopy company but wasn't able to find one that would mess with it, they seem to favor the blowing method, but I didn't want to alter the look of the original design.
As for cowling, I got a nosebowl for a T-18 from Aircraft Spruce and did the rest with foam and glass.
Randy
Randy
- Elève Pilote
Hello,
In the time(period) 2003 we made the canopies do at Mécaplex in Swiss among 4!! Among which 2 smoked green.
http://www.mecaplex.ch/mecaplex.asp?s=925&l=en
