- Hinge brackets.png (128.87 Kio) Vu 1824 fois
Clarification nécessaire.
Merci de bien vouloir m'envoyer une photo des plans originaux des supports de charnière. Je pense qu'il y a une erreur dans la mesure «B» pour le support n ° 4. Merci. Charlie
Re: Clarification nécessaire.
Bonjour Charlie
The set of CP 750 plans I have is the sama edition as yours. I also have plans for the CP 605 (which aI built and fly) and for the CP 328 which I am building… those are in milimeters and identical except for the number of flaps hinges, 4 for the Emeraude and 6 for the Diamant.
here are the dimensions:
Dimensions in the same order as on the plans:.... A... B... C...
Tip aileron hinge:..................70mm...25mm...23.5mm
Middle aileron hinge:...............89mm....41mm...24mm
Flaps and half aileron hinge:.......97mm....45mm...28
(other half aileron hinge is Steel with balance weight on an other plan sheet)
Hoping I am not too late.
Good luck
Good luck
